I was thinking of putting a tee with a coupler where the big rubber line goes into the valve block under the dash for the factory spools then welding a return fitting on the top cover....(the cover already has an angled filler with cap welded on it....)
That was the only solution I could think of to use the loader plus the other remotes....
where is your power steering pump at on the 504 that you were dumping to it after the pb spool??
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
