F12/F14 transmission question
Posted by tractorhank on October 13, 2008 at 15:36:09 from (24.124.104.36):
I have a F14 and have a transmission question. On the right side of the transmission right below the belt pulley is a big castle nut with a cotter key and oblong washer behind it on the outside of the transmission. What is this for and how do you adjust it and should you be able to turn the shaft and nut from the outside? Thanks, Hank. 785-748-0061.
