Scotty - You make a very good point - one I had not considered! Under certain conditions a grossly mistimed ignition COULD cause an engine to run hot enough after extended operation to cause dieseling at shutdown.
OTOH such situation would also be accompanied by some other somewhat dramatic symptoms: extreme knocking (timing too far advanced); glowing exhaust manifold/flames out of the exhaust (timing way retarded); extreme loss of power and overheating (timing too far out either way).
So I still submit it's probably not likely the average guy fooling with an old tractor will ever experience running on caused by bad timing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
