Re: h steering
Posted by Steven f/AZ on October 16, 2008 at 07:15:44 from (216.67.213.217):
In Reply to: h steering posted by donald schnupper on October 15, 2008 at 15:54:30:
Good luck, I've spent $200 in parts on my H narrow front and it still wobbles going down the road.
I rebuilt the steering u-joint, new bushings and bearings in the bolster, turned the gear 1/2 turn to get new cogs in contact when on-center, and added the lower bolster wedge, along with running 10psi in one tire and 25 psi in the other.
Start with the simple things like the u-joint under the hood, then see if you have the full steering gear that can be turned to less worn cogs.
