Re: h steering
Posted by LA in Wi. on October 16, 2008 at 07:24:32 from (71.98.0.150):
In Reply to: Re: h steering posted by Steven f/AZ on October 16, 2008 at 07:15:44:
Steve, I did the same things you did with my H. Mine tightened up some, but still wobbles.
I use the tire pressure trick and that helps a lot. I rarely go over 1/2 throttle in 5th to avoid the problem. I spent too much for poor results.
I"ve heard of guys saying their steering is now tight; wish I knew how to do that. This problem drives me nuts.
LA in WI
