Re: IH 2150 paint problem
Posted by El Toro on October 16, 2008 at 08:55:35 from (205.188.116.73):
In Reply to: IH 2150 paint problem posted by Danto on October 15, 2008 at 19:57:02:
third party image
If you do a search for paint bubbling you will find what mkirsch is telling you. The IH 2150 paint probably wasn't cured enough. It will probably need to be stripped and repainted. I would use acrylic enamel or the single step urethane with hardener. You need to use a supplied air system when spraying these paints with hardener. I painted a tiller with PPG's single stage paint code 71310. Looked better than when new. Hal
