I'm almost positive the pump is in time. We lined up everything like it is supposed to be. No fuel is getting to the injectors. All lines are loose at the injectors but no fuel squirts out when cranking. The throttle is wide open. When the lines are lined up under the pump site window, the timing pointer is at 8 degrees on the bell housing. It is a Rossa Master pump. We loosened the fitting for one of the steel fuel lines at the pump and no fuel comes out there either when cranking. For some reason, fuel does not seem to be exiting the pump.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
