Re: Farmall 806 won't start
Posted by don in mn on October 16, 2008 at 13:19:30 from (64.61.202.112):
In Reply to: Farmall 806 won't start posted by Shahn on October 16, 2008 at 10:15:41:
I have a 450 diesel that I had the same problem. I ran it low on fuel. I changed the fuel filters, cleaned the fuel screen in the pump, cleaned the water trap, drained the fuel tank, and cleaned it. Primed it just as the book said, had fuel to the pump, but not to the injectors. To shorten up the story, the roller pin in the shaft that holds the throttle lever had sheared off. When I went to start it switch to diesel from gas no go. Replaced the pin, cracked the injectors and started right up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
