Re: Farmall 806 won't start
Posted by mazemeister on October 16, 2008 at 18:53:38 from (24.188.81.230):
In Reply to: Farmall 806 won't start posted by Shahn on October 16, 2008 at 10:15:41:
just for kicks, change both fuel filters and see if that helps.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
