Re: Farmall 806 won't start
Posted by karl f on October 17, 2008 at 08:30:39 from (209.188.106.159):
In Reply to: Farmall 806 won't start posted by Shahn on October 16, 2008 at 10:15:41:
have you bled the air out of the filters? no amount of bleeding on the pump and injector ends will remove the air in the filters.
karl f
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
