Help with A governor setup
Posted by Tims A on October 18, 2008 at 16:03:12 from (66.67.110.191):
I am reassembling the carb (Zenith)onto the tractor. Per the manual, throttle set wide open, this pushed the rocker shaft arm toward the carb., I have pushed the carb rod back toward the carb. and can not screw the adjuster on the rod back far enough to get the pin to just slide in loosely. Whats wrong here?? I did rebuild the governor, and carefully reassembled. The arm on the rock shaft is at about 25 deg from vertical toward the back at wide open throttle.
Thanks,
Tim
