Re: Help with A governor setup
Posted by Gene Bender on October 18, 2008 at 17:02:07 from (67.55.226.167):
In Reply to: Help with A governor setup posted by Tims A on October 18, 2008 at 16:03:12:
Did you get the butterfly on the throttle shaft installed correct as with the throttle wide open and the rockshaft back towards the carb the clevis should be able to adjust so the pin goes in with the throttle shaft open.
