Re: super m output
Posted by the tractor vet on October 18, 2008 at 18:41:18 from (99.167.208.219):
In Reply to: super m output posted by switching sides on October 18, 2008 at 17:57:07:
Well depending on just what is inside the engine for pistons and what shape the cam is in 60 HP is not out of the question here . I am pulling 60 HP out of my S/MTA with 4 1/8 M&W flat tops With my dist. set up on the timing curve and has real good bottom end performance will spike on overload to 68 hp , Now my one buddy's S/MTA with the 8500ft high Alt. pistons in 4 1/8th with a stock 450 cc. and just port matchen along with a 450 carb and tweeking on the dist. will pull 94 hp at PTo speed on 93 octane gas. This tractor is used everyday on the farm .
