Farmall 130 compression
Posted by Hugh MacKay on October 20, 2008 at 05:01:24 from (209.226.247.64):
I should know this, however the memory upstairs is not with it. What is considered good usable compression for a C-123 in a Farmall 130. I know this tractor is down in all cylinders, however lately I'm getting fouling with oil on number 2 plug. I've got the plugs out this morning, thought I might check compression before I go at the real reason I have it in the shop. I put it in to replace front crank seal. Don't need help with crank seal, I have the tools and this is my 3rd one.
If that compression is bad enough I may just go for a rebuild. Don't really want to do that this fall, my snowblade push frame is on the tractor, we may be close to snow and I really don't need the exercise of removing cultivators from 140 then changing snow blade from 130 to 140.
