Re: Farmall 130 compression
Posted by Bob M on October 20, 2008 at 07:02:01 from (151.190.254.108):
In Reply to: Farmall 130 compression posted by Hugh MacKay on October 20, 2008 at 05:01:24:
G'morning Hugh!
I'm going from memory here. But as I recall compression for a healthy C123 should be 80 - 85 psi or so.
What's more important however is CONSISTENT compression readings cylinder to cylinder. If compression on #2 is about 10% or more less than the average of the other 3 cylinders there's a problem. But it could be as simple as incorrect valve lash on the problem cylinder.
Were the tractor mine, and if the engine otherwise starts/runs OK I'd check the valve lash, put the hottest plugs I can find (Champion D23, Autolite 388 or similar) and go ahead and use it "as is" thru the winter.
...Bob
