Re: Help solve a Super A question
Posted by glennster on October 22, 2008 at 05:54:19 from (99.131.129.77):
In Reply to: Help solve a Super A question posted by Larry in GA. on October 22, 2008 at 05:29:45:
originally it was a 6v pos ground, however, who knows if it was converted to 12 in the past. couple things to look at that may help id it. first, if it has lights, pull the bulb and see if its 6 or 12v. then see if it has a voltage regulator or cut out relay. if a cut out, 2 wire, its a 6v. if a 3 or 4 wire reg could be 12v, there should be some numbers stamped or inked on it, look for 6 or 12v markings. and look at the genny. if its an alternator, its a 12v, if a genny, more than likely its a 6v, however the genny could be a 12v too. the early 60"s gm 12v gennys will fit on the tractor too, i have 3 tractors with 12v gennys on em. one other thing to chek is the coil. look for a ceramic ballast resistor just before the power at the coil. also see if the + side of the coil goes to the distributor or the - goes to the dist. + to distributor is pos ground, - to the dist is neg ground.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
