Re: Help solve a Super A question
Posted by Hugh MacKay on October 23, 2008 at 17:50:24 from (216.208.58.121):
In Reply to: Re: Help solve a Super A question posted by glennster on October 22, 2008 at 05:54:19:
Glen: There are 6 volt alternators. I have a Super A that has been 6 volt alternator 15 plus years. All you need do is change the internal voltage regulator on a GM Delco alternator.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
