Re: Light switch wiring ???
Posted by mkirsch on October 23, 2008 at 18:11:55 from (67.240.251.254):
In Reply to: Light switch wiring ??? posted by Bucky on October 23, 2008 at 17:54:57:
Bucky, that's the wrong switch. A 4 position switch is for not only controlling lights, but also controlling the charge rate. The four positions are low charge, high charge, dim lights, bright lights.
It is meant to be used with the earlier generator cutout design instead of the voltage regulator that you have right now.
There's no problem using the switch, it'll just have two OFF positions. Unfortunately I don't know the wiring for that particular switch.
