Re: Starting a McCormick-Deering 10-20
Posted by spiffy1 on October 23, 2008 at 19:08:38 from (70.41.136.71):
In Reply to: Starting a McCormick-Deering 10-20 posted by Bob S. on October 16, 2008 at 18:33:10:
Sounds like you're on the right feature, but I'm not sure it's working: when engaged [yes, down], as LenNH mentioned, you should hear it click at TDC. Once it starts and has enough RPMs it should stop clicking.
If you have someone there to watch, you can pop the cap off and see it too.
Thanks LenNH for putting safety a bit higher priority than I. I need a tatoo on my forehead and signature line on any forum I post to: "Do as I say, not as I do" or perhaps "Following my example could be hazardous to your health." :oops:
edit: I think LenNH was noting: listen for the pawl to drop into the drive, I was noting listen for the mag to snap on release. Same difference, except again, if the mag is turned on [it would be if you're intending to start a tractor] knowing something isn't right before you get to firing position is much smarter!
This post was edited by spiffy1 at 19:13:14 10/23/08.
