Re: In regards to Bob F's post earlier on condensation in M
Posted by wayne in mn on October 25, 2008 at 09:18:56 from (66.188.156.38):
In Reply to: In regards to Bob F's post earlier on condensation in M posted by Randy-IA on October 25, 2008 at 09:08:54:
The transmission cover bolt holes are not open ended into the transmission so nothing gets into the gear lube from water in the bolt head depression. Looks are deceiving.
There is a lot of open space in the housing so water vapor condensation is the biggest factor.
