If the fuel were old, the tank may contain some gel, water, or trash (rust). It was always my experience that the tractors with these gravity fuel systems will run rough until the fuel tank, fuel line and carb. is flushed out, that is after they have set up for a while. Before you start doing too many adjustments, I would first drain and clean the fuel bowl and drain the carburator and blow out the fuel line. I have seen the time when the carburator bowl had to be drained several times to clear out all the water condensate, crud and trash.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
[More Ads]
