super super fc-c timing
Posted by lachleaves on October 28, 2008 at 14:32:50 from (81.141.7.172):
ok fellas
you'll be glad to hear i've got the old timer started! and i pretty much know where everything is and how it works - how'as about that??
anyway, she does start, but runs unevenly. i've checked most things, but not the timing - how do i check it or set it up??
and, i have stripped and cleaned the carb, but what should be the position of the mixture screw?
thanks again
lachleaves
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
