SM with MW live Hyd pump
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Justin on March 27, 2000 at 15:50:40 from (208.196.37.202):
I took my pump a part to replace the seals, and I noticed that all the needle bearings are missing two needles. Are the needle bearing suppose to be that way?
The pump is split into three peices. Is there to be an O-ring between the center peice, because there is a grove for an O-ring. There would be two 0-rings, one on each side of the center peice. Any info would help.
Post A Followup
: Re: SM with MW live Hyd pump
