Re: Farmall H Trans. Knock Update
Posted by Janicholson on November 01, 2008 at 06:38:51 from (66.188.163.79):
In Reply to: Farmall H Trans. Knock Update posted by Andy Motteberg on October 31, 2008 at 16:47:00:
I believe (though it was a while ago) that I indicated that gear as the culprit. It is the constant mesh drive gear used in every gear except fifth. A donor trans, or gears will be needed. The lay shaft gear will also be toast. My uncle had an H with that gear damaged. Clicked every day for 6 years. JimN
