Re: 424 ignition problem
Posted by Tedly on November 01, 2008 at 07:26:08 from (166.197.49.92):
In Reply to: 424 ignition problem posted by Tedly on October 31, 2008 at 22:50:42:
Wow, thank you both for the great information. I"ll check it today or tomorrow and tell you what I found.
For my curiousity, is the only purpose of the external ballast resistor to step down the battery voltage so less voltage is applied to the coil, points and condenser to make them last longer? If I need a new ballast resistor and don"t have the exact value, should I size it so approximately 6 to 8 volts is applied to the + side of the coil?
Thanks again
