The purpose of the ballast resistor is to drop sufficient voltage (often 12 down to 6) so the coil only draws its rated current and dont overheat and likewise the points switch whatever current they are rated to handle so they dont burn up prematurely.....
The ballast should be sized so it drops enough voltage such that the remaining voltage is what the coil is rated for. Typically that would be 12 volts down to 6 so if the coils primary is 1.5 ohms the ballast would also be around 1.5 ohms for a 50/50 voltage divider. If you have a 6 volt coil measure its primary resistance (between its lil + and - terminals) and the ballast would be near the same and typical ones are in the 1.25 to 2 ohm range
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
