Actually all the tapped holes and threads were at or near perfect on my transmission case. And I only had one bolt break off, it was one of the cover bolts. Just welded a nut on the end of it, heated the area around it and turned it out. I did have to find a better drawbar bracket though cause the one was so badly worn oblong.
In reply to Charles it has a T/A the lever is somewhat hard to spot in the pics though. It also has a couple rare options including original shutters and linkage, and I also have a power steering setup for it, but I need to rebuild the cylinder/valve assembly first. It will evetually be restored once I come up with the time.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
