Re: case ih 695 rear brake problem
Posted by JimB2 on November 02, 2008 at 15:54:46 from (99.241.179.24):
In Reply to: case ih 695 rear brake problem posted by hatty on November 02, 2008 at 14:02:59:
Hi have you checked the brake lines that run from the master cylinders to the rear brakes?
These lines run on top of the transmission cover and under the sheet metal cover to under the seat and then go into the rear brakes. Could be more difficult to check on the xl model as I believe that indicates there is a cab installed.
JimB
