Re: case ih 695 rear brake problem
Posted by hatty on November 02, 2008 at 18:21:11 from (123.211.26.115):
In Reply to: Re: case ih 695 rear brake problem posted by JimB2 on November 02, 2008 at 15:54:46:
thanks JimB2, there is hydraulic oil dripping to the ground when engine is running, which fills the drive shaft tray, and falls elsewhere, but seems to come from the top of the transmission case which as you mention would be under the cabin floor. It is not a lot of oil but definitely there and seems worse as the the brake condition has deteriorated. I will investigate this and reply. regards hatty
