460 coil wires
Posted by iowafarmall on November 02, 2008 at 19:40:05 from (66.43.214.78):
put electronic ignition on 460 today. It was wired for the points with a black switched wire and a white wire on the negative terminal of coil and the wire going to distributor on positive terminal. The ignition instructions said to have red wire and switched wire on positive side and black wire of ignition on neg side. Where do I put the white wire? It was not starting with the white wire still on the neg coil terminal but it started and ran fine when I took wire off. Do I put the white wire over on the positive side or does it belong somewhere else?
