Posted by Janicholson on November 03, 2008 at 18:48:49 from (66.173.50.172):
In Reply to: IH 504 Will Not Fire posted by Joe MD on November 03, 2008 at 17:51:35:
Compression is necessary. Pull the plugs open the throttle, ground the coil hot wire to the block, and put a good compression gauge in #1 spark plug hole. Crank it at least five compression strokes. put a teaspoon of oil in the cylinder, crank several revolutions to spread oil. Check compression again. It should be over 125! If real low or none, the valve cover needs top come off to check valve action and timing. Keep us in the loop. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
