Re: exhaust valve on Farmall A
Posted by Gene Bender on November 04, 2008 at 04:35:14 from (67.55.226.167):
In Reply to: Re: exhaust valve on Farmall A posted by Janicholson on November 03, 2008 at 17:24:30:
How did it obstruck the view what implement did you have that caused the problem and which implement did you have trouble lifting.
