Re: exhaust valve on Farmall A
Posted by Janicholson on November 03, 2008 at 17:24:30 from (66.173.50.172):
In Reply to: exhaust valve on Farmall A posted by joey sharp on November 03, 2008 at 15:21:59:
Prior to the use of Hydraulics on A-B Farmalls, IH made an exhaust powered lift system. It was composed of a manifold with a valve that could shut off the muffler, and a pneumatic cylinder that used the resulting back pressure to lift implements. It worked pretty well. but was not anywhere as competent or powerful as Hydraulics. The issues were deterioration due to corrosion/moisture,
Low power, poor position control, clumsy location for the "power" cylinder, and obstruction of view.
The only claim it could make is it was "live" (it worked with the clutch disengaged. JimN
