pneumatic lift on an A
Posted by dmiller on November 04, 2008 at 08:35:07 from (65.125.253.194):
I have a pneumatic lift on a farmall a. New cylinder seal, new rubber washer in the control valve, cleaned out the control valve, greased all fittings, have a movable valve at the exhaust manifold (though a pretty rusty manifold).
What should I check next. I get air flow through the lines to the cylinder, but am developing no volume to speak of or pressure.
