Re: pneumatic lift on an A
Posted by Gene Bender on November 05, 2008 at 03:47:47 from (67.55.226.167):
In Reply to: pneumatic lift on an A posted by dmiller on November 04, 2008 at 08:35:07:
Could be several things. Is the seat in the pressure valve smooth and not rusted. When the lever is pulled back and locked is the linkage to the pressure valve tight and is the valve closed complete as then there should be just a very small amount of exhaust coming out of the muffler. Is the piston leather oiled good and no leakage by the piston. What implement are you trying to lift.
