Re: IH 504 Will Not Fire
Posted by Wayne from MN on November 04, 2008 at 09:53:09 from (66.228.243.49):
In Reply to: IH 504 Will Not Fire posted by Joe MD on November 03, 2008 at 17:51:35:
Try removing the spark plugs, squirt a small amount of gasoline in each hole, replace the spark plugs & wires. Turn on the ignition switch & try starting. If it fires, you have a fuel delivery problem into the cylinders. This may be a bad intake gasket or camshaft not doing it's job. You can take the valve cover off & observe the valve action.
You can call me if there are other questions.
218-770-4623.
