Super C compression readings...
Posted by Matthew(Mich) on November 04, 2008 at 18:24:23 from (67.177.148.199):
Did a compression test on my super c because it smokes some. This is what I found...
Throttle fully advanced and all plugs removed.
Dry test
#1 cylinder 100psi
#2 cylinder 100psi
#3 cylinder 100psi
#4 cylinder 25psi
Wet test...
#1 cylinder 115psi
#2 cylinder 115psi
#3 cylinder 115psi
#4 cylinder 25psi
No change in the #4 cylinder I'll check for stuck valves tommorrow. What are your thoughts here?
Matthew
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
