Re: Super C compression readings...
Posted by Hugh MacKay on November 05, 2008 at 05:23:54 from (209.226.247.6):
In Reply to: Super C compression readings... posted by Matthew(Mich) on November 04, 2008 at 18:24:23:
Matt: Are you getting any oil fouling of number 4 plug. I've got same in my 130, C-123 engine, 1, 3 and 4 are all over 100 psi, number 2 is around 65 psi and that plug keeps loading up with oil. Got to be rings in my opinion.
If your not getting oil fouling then I'd look to the valves.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
