Re: Has this ever happened to you?
Posted by Paul in MN on November 06, 2008 at 16:20:38 from (71.210.152.240):
In Reply to: Has this ever happened to you? posted by Dr. Bert on November 06, 2008 at 16:04:02:
It is possible that the adjustment screw on the rocker arm has loosened.
Or the rocker arm was not getting proper oil and the bushing on the rocker arm has badly worn.
Or the valve spring has broken so that the tappet was being slapped hard by the cam lobe. If spring is broken, the valve does not follow the cam so there may be too much slop in the push rod and it jumps out of place.
This same thing happened to my 401 Ford 9000 diesel...valve lash adjustment screw had backed off, the push rod was badly bent. It sure sounded bad, and it was very sudden. We towed it home to the shop.
Good luck,
Paul in MN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
