Has this ever happened to you?
Posted by Dr. Bert on November 06, 2008 at 16:04:02 from (72.36.57.58):
The H I am working on suddenly started missing after a very loud "backfire". Checked the plugs--#4 was wet. Put in a new plug--same miss. Ran a compression test--#4 had no compression--all others 120#. Pulled the valve cover and found that one push rod had "jumped" out of the tappet. The push rod was very slightly bent, but I don't think it was enough to slip out of the tappet. All I can think of is that that lifter was set up way too loose when last adjusted (not by me). All the others were set at 15/1000. What do you think caused this? Thanks.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
