Re: Has this ever happened to you?
Posted by RustyFarmall on November 06, 2008 at 19:31:29 from (209.152.78.71):
In Reply to: Has this ever happened to you? posted by Dr. Bert on November 06, 2008 at 16:04:02:
It is possible that particular valve is a bit sticky in the guide and at one point did not return to fully closed, which creates quite a bit of "slop" in the valve train. I had the same thing happen about 9 years ago while getting an H running again after it had sat for several years. I pulled the bent pushrod out, layed it down on a hard, flat surface and hammered it until it was straight again. That H gets regular use in the summer months and has never given me a lick of trouble.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
