Re: 6 volt charge
Posted by bcarter2 on November 07, 2008 at 06:27:23 from (74.14.106.230):
In Reply to: Re: 6 volt charge posted by John T on November 06, 2008 at 19:07:49:
What Should I expect in terms of charging amps for the tractor ? And a little topic, but would there be an advantage to putting on a voltage regulator as opposed to the cutout ?
Today I"m planning on checking the fuse in the switch circuit (hence I was asking what amp to expect, maybe it"s blown ?) I was then going to disconnect the 2nd wire that goes to the switch to isolate that there might be a problem there keeping it from Charnging.
Thanks for all you help.
