Re: international harvester A
Posted by Janicholson on November 08, 2008 at 15:18:28 from (66.173.50.61):
In Reply to: international harvester A posted by big glen on November 08, 2008 at 15:10:07:
Have you checked to see if there is a good vent hole open in the gas cap? Often the fuel just can't get replacement air.
Have you checked the spark when it stops to be sure it is the spark?
Pull a plug wire and hold it with insulated pliers about 1/4" away from the block.
If it has a nice blue spark, it is probably a fuel issue.
Engines run on the max spark volts when at Idle.
I think it is fuel related. JimN
