international harvester A
Posted by big glen on November 08, 2008 at 15:10:07 from (24.236.199.35):
I have a IH model A after running for about an hour quits, restarts but will only idle in low idle cannot increase speed until tractor is turned off for about an hour or so. Replaced the points,condenser,and coil, still does same thing. could the problem be in the mag timing? maybe one cog off any suggestions would be helpful. thanks Larry
