A few year ago when I got my farmall a I had a similar problem. For me it ended up being a bad bowl gasket/clogged air passage for equalizing internal bowl pressure. It would start and run great for about 3 minutes then flood itself, I"d get fuel in the air intake and if left long enough would have it run out the rubber hose between the carb, and air filter canister. You might check there for fuel to see if you are getting a similar problem. Another time cleaning it out and a new gasket and I haven"t had problems with it for about 2 years.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
