Re: McCormick-Deering model F-12
Posted by Andy Motteberg on November 09, 2008 at 13:23:35 from (4.143.216.72):
In Reply to: Re: McCormick-Deering model F-12 posted by AmyA on November 09, 2008 at 12:24:52:
The water jacket is the side of the engine, above the fuel pump. Look and see if it looks like the engine has a crack there, it is hard to find a block that is not cracked or welded. Does the tractor have the crank on the front? The crank goes on the front of the tractor. Push the crank in and try turning it, if the crank won't turn, the motor is stuck. Where are you loacted?
