Posted by JimB2 on November 09, 2008 at 16:54:24 from (99.241.179.24):
In Reply to: IH 574 weirdness posted by Jason from MI on November 09, 2008 at 14:33:57:
Jason, I would say it was fuel starvation, fuel filter(s) or fuel line is partially clogged. If it is not the fuel filter(s) then the favourite place for that model of tractor to clog is at the outlets at the bottom of the fuel tank. If you look under the fuel tank you will see the outlet at the bottom of each side of the tank. First thing would be to check the shut off valves at the bottom of the tank to make sure they are turn on fully. If the inlet pipe to the primary fuel filter is removed the fuel should flow the full of the pipe. If it doesn't the problem is between the tank and the fuel filter.
Do an archive search on Floridaboy and read about his 674 which is basically same as 574.
How was the parking brake, foot brakes? Did you smell the crankcase oil dipstick for Diesel fuel smell?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
