Re: sticky clutch solution?
Posted by mkirsch on November 10, 2008 at 09:02:24 from (64.80.108.53):
In Reply to: sticky clutch solution? posted by ScottyHOMEy on November 10, 2008 at 08:58:36:
If the clutch was "sticky" the tractor would not stop moving when you depressed the pedal. Same for clutch rusted to the flywheel. You couldn't stop without shutting off the engine.
On a newer tractor, the issue you describe would be solved by adjusting the transmission brake. An H does not have a transmission brake.
