sticky clutch solution?
Posted by sgtbull on November 10, 2008 at 08:58:36 from (166.159.173.247):
The clutch on my "40 H seems a bit "sticky". The pedal has the correct free travel, but when depressed, it seems to take quite a while for the input shaft to quit turning. You can"t get in a hurry to put it in gear or you"ll clash gears. Its not a problem if you"re going from one gear to another, only when going form engaged clutch in neutral to whatever gear you are starting out in. This tractor is used frequently, and the clutch hasn't stuck to the flywheel or pressure plate from rust or anything like that, and it was out of the tractor and cleaned 3 years ago. It has worked fine until the last month or so and seemed to develop suddenly. Could it be as simple as adjusting the clutch fingers?
