Re: sticky clutch solution?
Posted by ScottyHOMEy on November 10, 2008 at 09:35:59 from (70.105.230.210):
In Reply to: sticky clutch solution? posted by sgtbull on November 10, 2008 at 08:58:36:
I don't think it's going to be your clutch, sarge. If your freeplay is set okay, as it soundl you have done, and the pedal can be depressed all the way, adjustment of the fingers is likely not a problem.
It sounds more like a sticky pilot bushing at the rear of the crankshaft, though I'm not sure why that would develop suddenly. I don't remember where you're located, but the problem can become more pronounced in cooler weather when the tranny lube gets stiffer, making the input gears less "willing" to come up to speed against a slowly turning driveshaft.
